Are my fans properly set for good cooling from bottom to top ?
dazkyl
1,036
I bought this case last week and i wanted to ask if the fans are properly set for intake from bottom and side to exhaust from rear and top.
The only thing i did was that i installed the 2 bottom fans and i think they are intaking the air from bottom as it should be , but i dont know how to check if the fans are exhasuting or intaking.
Here are 2 pictures that i took.
And about the cpu cooler , im about to change its position and make it face the rear fan so that the hot air is immediately pushed out of the case.
http://oi39.tinypic.com/30w4brn.jpg
http://oi42.tinypic.com/dc7hn7.jpg
It looks like the cpu fan is already pushing air out the back. All of the white fans look correct, but I just can't tell about the clear fans. They almost look like they are exhausting. You are just going to have to turn it on and feel with your hand. You'll know immediately if they are pushing or pulling.
Looks like you could spend more time on cable management! lol
Whats wrong with the cable managment ?
Just nitpicking, but I think you could have gotten most of those cables behind the back side panel. Better cable management makes for more efficient cooling. I JUST built a PC last night and probably spent more time managing the cables than I did putting the actually pieces together. I got almost all of them behind there.
I did put most of the wires on the other side of the panel ,but i just couldnt for some of them as they are short.
