[SOLVED] Are my parts compatible and work well together?
Dec 27, 2018
So I see the community on here always active helping others out and I was just wondering if I could get some help also, I'm getting a new PC soon and I get to build it and I was wondering if the parts are correct for each other.
Parts:
CPU: Ryzen 5 2600X 3.6 GHz
MB: TUF B450M-PLUS GAMING
RAM: 16 GB (2 x 8 GB) DDR4-3000
STORAGE: M.2 120 GB (Boot Drive) - 1TB HARD DRIVE (Hard Drive)
GPU: RTX 2070 8GB
PSU: 600 W 80+
PCPartPicker: https://pcpartpicker.com/list/dmCFhy
Also, I do have my own 1TB hard drive that is why it is not in the PCPartPicker.
Dec 27, 2018
Just wondering why I shouldn't, not to come out as hateful towards your comment but the ryzen 5 2600x is a great match for rtx 2070 due to compatibility and they don't bottleneck also they can be overclocked too.
I just want your two cents on that comment
punkncat
Commendable
Apr 3, 2018
1,275
67
1,540
76
Cost of the GPU vs the rest of the components.
To expound on that...(sorry terrible storms, internet acting crazy)….you have a $500 card selected to use with what many would consider a "value" gaming option in the R5. Unless the Ray Tracing is the specific thing you are after, even for it's currently limited applications, you could upgrade to an Intel i7 system and a 1080 for roughly the same money. There is no question which of the two of those would perform better for gaming aside from the 'RT' ability.
Just my .02
