Are my parts compatible?
Buddermoose
I am looking at building my first gaming pc, and am wondering if these parts are compatible if they arent could you recommend me some that are compatible? my budget is 1200 dollars:Motherboard: http://www.newegg.com/Product/Product.aspx?Item=N82E16813131819 190
Harddrive: http://www.newegg.com/Product/Product.aspx?Item=N82E16822148834 100
Graphics Card:
http://nvidia.links.origin.channelintelligence.com/pages/redirector.asp?nIID=2333 43835&nRGID=2304&nVID=11302&nRow=4&sCt= 325
OS: Windows 7 home premium 64 bit ( buy this at best buy or office depot) 100
Cpu: http://www.newegg.com/Product/Product.aspx?Item=N82E16819116501&nm_mc =OTC-pr1c3grabb3r&cm_mmc=OTC-pr1c3grabb3r-_-Processors+-+Desktops-_-Intel-_-19116501 325
PowerSupply:http://www.newegg.com/Product/Product.aspx?Item=N82E1681719
0029 60$
Cooling System: http://www.newegg.com/Product/Product.aspx?Item=N82E16835181010 60
RAM: http://www.newegg.com/Product/Product.aspx?Item=N82E16820226337 115
Optical drive: http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204 20
Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811119233 60$
I would suggest building it on www.pcpartpicker.com, they have a great, helpful community, and it shows weather or not your parts are compatible!
Thanks for the advice! i will definitely look into it:)
be sure to add my answer as "best answer" and close the forum!
