Question are my parts compatible
May 26, 2019
5
This is my first PC build and i have had issue after issue which is my own fault of course but i have really hit a wall when i put it together first the PC powered up but i could not get any visuals using my HDMI i was told it was because my MSI Z97S Mother Board has LGA 1150 sockets while my CPU is LGA 1151 so i bought my new DDR 4 Ram and GIGABYTE Mother Board but now the power cuts off in 1 second any help is appreciated
my PC parts
Motherboards:
GIGABYTE Z37OP D3
MSI Z97S SLI KRAIT EDITION
Power Supply:
Corsair CX65OM
CPU:
I5 6500 LGA1151
GPU:
GTX 970 iChiLL AirBoss
RAM:
Corsair Vengence DDR3 2X8
Corsair Vengence LPX DDR4 2X8
Case:
NZXT Phantom 530
May 26, 2019
5
i checked a list for the Z370P supposedly the 15 8600k is compatible if i buy it will everything be in order like will the power supply be enough
Yes, everything will work with that cpu.
it's a nice leap in performance over the old i5 6500 as it's much higher clocked, unlocked and has 2 more cores.
You'll need an aftermarket cooler for it though as it doesn't come with one and Intels stock cooler wouldn't be enough anyway.
Reactions: havoc4gaming
You could sell the old I5 aswell as they still can be used for lower end systems.
An 8600k and z370 will work together well and the 6 threads will be great for games and decent for rendering tasks, although it would be better for rendering if it supported hyperthreading.
Id suggest a hyper 212 as a cheap aftermarket cooler for stock clocks or a mild overclock. A bequiet dark rock pro 4 would be my choice for a good looking tower cooler for overclocking.
Latest posts
