Y yas33n Honorable Nov 11, 2012 102 0 10,690 May 29, 2013 #1 Heyy! The title says it all, they're £2 per fan(4 mounts) are the worth it? Cheers
mattius92 Distinguished Aug 27, 2010 504 0 19,060 May 29, 2013 #2 I do not like rubber mounts, they don't hold very well and look kinda tacky. A quiet built fan will do a better job then rubber mounts.
Y yas33n Honorable Nov 11, 2012 102 0 10,690 May 29, 2013 #3 mattius92 : I do not like rubber mounts, they don't hold very well and look kinda tacky. A quiet built fan will do a better job then rubber mounts. I have a CM megaflow 200mm and some stock CM fans
X79 Honorable Apr 17, 2013 3,039 0 13,460 May 29, 2013 #4 Rubber is good for reducing vibration to the case and thus the noise. So if you care about noise, sure it's worth it. A long with a good fan like mattius said.
mattius92 Distinguished Aug 27, 2010 504 0 19,060 May 29, 2013 #5 yas33n : mattius92 : I do not like rubber mounts, they don't hold very well and look kinda tacky. A quiet built fan will do a better job then rubber mounts. I have a CM megaflow 200mm and some stock CM fans Use the rubber mounts then, that will help better then having to buy new fans. They will work for what you need them for.
Y yas33n Honorable Nov 11, 2012 102 0 10,690 May 29, 2013 #6 So I'm thinking of trying them out on the side pael as it's kinda loose. Thanks
