Are some parts of my PC outdated for the bigger triple A games?
drainmano
9
Hello!
Lately i've played alot of games like R6:Siege, Battlefield 4 & 1, or AC:Origins f.ex., but i've noticed that i can't for the life of me get a stable framerate above 60. No matter what settings i try, i can't go above that threshold with a 144hz screen.
It's not that i can't play without it, but on games like AC:Origins the framerate is usually around 30-40, and sometimes it drops even further, even with the lowest settings. I can run Siege on stable 60 most of the time, except when explosions and rapid movement occurs over a few seconds.
PC specs:
- ASUS Z97-A, Socket-1150
- I7-4790K CPU @ 4 ghz
- 16 gb ram DDR3
- GTX 1080
(If you need any other information please let me know).
I do feel my pc should be able to run most of the newer games without any problems (maybe not all on ultra quality), but i might have overlooked something obvious perhaps.
Thanks in advance.
I do not remember where to check the model of the cooler, but i have 2 internal and 1 external fan, if that answers your question? I have never overclocked anything before, so not quite sure how to do that unfortunately.
I did send it back for repairs about a year ago, they switched out power supply and cooler, because they were faulty. It's been like this for about 2 years i believe. Can't tell exactly because i didn't play these games 2 years ago, but i've never felt that it performed as well as it should have.
If i were to do a complete wipe, and install the system again, would that help/how would i proceed to do that?
Well if you had viruses and malware that can't be removed by software then if should get rid of those, doing a clean install of Windows gives you a fresh start so you'd need to get motherboard/GPU drivers and such. I would only use it as a last option though, try the suggestions above first.
Alright, i'll do that first. Do you recommend any antivirus programs? I do have AVG free, like many others.
Did all the things you mentioned, everything is much better now, and i suspect i had a few viruses that caused it, maybe other stuff aswell.
When it comes to temperature, CPU topped at 80 degrees after half an hour, while the GPU topped at 59 degrees.
Thanks alot, improved my experience by a huge margin :)
That's still quite warm for the CPU, are you using the stock cooler or a aftermarket one?
The cooler i have now is Cooler Master Hyper TX3 Evo CPU.
