[SOLVED] Are there 95mm case fans?
Nov 11, 2021
224
My question is, are there 95mm case fans? Because I just measured the length of my existing case fan, and it's 95mm. I only heard of 92mm fans, did I measure it wrong or are there 95mm fans? Thanks.
I had an old Dell Inspiron 580 that had either a 90 or 95mm rear exhaust fan. I don't remember where I bought it, probably Amazon, but they are out there.
I just looked on Amazon and they have either 90 or 92mm, no 95mm. The difference between 90 and 92mm is so small I don't know how you would determine which one you have. Order both and return the one that doesn't fit.
Alright thanks for the advice! Much appreciated!
Reactions: emitfudd
