I posted a thread a while ago about a problem I have, I turn on my computer, a second after it turns off itself. Sometimes it will turn back on itself after it turns off. In my last thread, someone told me I need standoffs. So from what I understand, the purpose of standoffs is to raise the mb up off the wall of the case, so it doesn't touch it. So I didn't install any brass standoffs, but it looks like my case already has standoffs built in. Here is a picture of one:
If you can't tell from the picture, the thing with the hole in it is raised up about half a cm off the board. And, this "standoff" is not the wall of the case, it's a little platform raised up off the wall. You can see through those larger holes, under them is the actual wall of the case.
Something else happened. My computer was in sleep mode, I wanted to turn it off so I pressed the power button (usually it will wake up when I do this) and it just turned off immediately. I just left it, and the next day I turned it on, and the same stuff I had running before it went to sleep started up.
Don't know if it makes any difference if it happens in sleep mode, but may as well let it be known.
