so I should get an ATX MB and which one should I getYes they will fit but why are you getting a micro ATX MB if the rest of your system is going to be ATX?
Great case by the way! I have it and I love it.
Prime Z390-Aso I should get an ATX MB and which one should I get
So what do you think I should get?Yes they're compatible. I'm just not a fan of Kingston anything, esp not that dramless A400
At that price Adata Su800 https://www.amazon.com/ADATA-SU800-512GB-3D-NAND-ASU800SS-512GT-C/dp/B01K8A2A0ESo what do you think I should get?
And thanks for the help.
Alright thanks man I’ll make sure to switch it out for this one!
I’ve decided to change the motherboard to the prime Z390-A would this change help?NZXT H510 - Specifications Page
MSI Geforce GTX1660 SUPER™ VENTUS XS
Be Quiet Pure Rock Slim CPU Cooler - Data Page
Gigabyte B365M DS3H - Specifications Page
Gigabyte B365M DS3H - CPU Support List
Of Note:
Case Max Graphics Card Length w/Front Water Cooler: 325mm
Case Max Graphics Card Length without Front Water Cooler: 381mm
Graphics Card Length: 204mm
Case CPU Cooler Clearance: 165mm
CPU Cooler Height: 124.8mm
Motherboard Supported Memory: Support for DDR4 2666/2400/2133 MHz memory modules
Your Selected Memory - DDR4-3000
Motherboard Initial BIOS Version: F1
Your Selected CPU's Required BIOS Version: F2 - You may need a BIOS update before your CPU is compatible with the motherboard. You would need a CPU supported by BIOS version F1 installed to update the BIOS to version F2. This all depends on what BIOS version your motherboard comes with.
-Wolf sends
How would I know if I need to bios update?The RAM should be ok now. You may still need BIOS update.
-Wolf sends
Sorry I’m new at this.
Ok thanks for the helpSome manufacturers will add a sticker to the box the motherboard comes in which states what BIOS version is installed. Otherwise, it's just a guess. You won't know until you try the new CPU. If you run into problems, you likely need a BIOS update.
-Wolf sends
