Are these components good enough for a gaming PC? Help appreciated as I don't know too much about components.
fifa500
142
Hi, I don't have a very good understanding of PC's but I'd like to get into PC gaming. I would like to know if these components put together be enough to run Battlefield 4. Any help would be appreciated because I am very unsure of what to do. I have left out windows software but I do acknowledge that I'm going to have to buy that too as well as a case. I have a disk drive, gpu, ram (2x4gb), 500gb hdd, and an 15 cpu. Do I need more things for a gaming pc or is that it? Here are the minimum requirements of battlefield 4: http://bf4central.com/battlefield-4-system-requirements... Thanks in advance.
Here are the links to the components:
http://www.amazon.co.uk/LiteOn-IHAS124-04-Height-Intern...
http://www.scan.co.uk/products/430w-corsair-builder-ser...
http://www.scan.co.uk/products/8gb-(2x4gb)-corsair-ddr3-vengeance-racing-red-pc3-17066-(2133)-non-ecc-unbuffered-cas-11-11-11-27-xm
http://www.scan.co.uk/products/500gb-western-digital-wd...
http://www.scan.co.uk/products/intel-core-i5-4430-s-115...
http://www.scan.co.uk/products/1536mb-evga-gtx-580-40nm...
http://www.amazon.co.uk/dp/B00CYWEZXA/?tag=pcp0f-21
I am aware that I don;t have a case and any software such as windows 8. I'd just like to know if these parts are compatable with each other and work well with battlefield 4. I have a budget of around £500 minus the case, monitor and windows 8 software so please keep that in mind when suggesting any changes. Thanks for any help.
fifa500
142
Im not sure which component is the PSU. Sorry about how little I know about these things. I know about cpus, ram and gpus but I dont know what a PSU is.
fifa500
142
Thanks. I am paying £120 for it for the GTX580. Can you recommend a PSU for me if you don't mind
Edit: I am paying £35 for the current PSU so it would be ideal for the price to be somewhere around that.
fifa500
142
So the new power supply along with all of the other components will be compatible together? I'll post the model of each component I'm using as you're not going to be clicking on the links, if you need me to.
fifa500
142
Last question. Will the GPU, CPU, RAM and any other necessary parts be able to run Battlefield 4. I'll post the minimum and recommended specifications to run the game if you would like me to. If yes, what setting do you think I can run it at (low, medium, high or ultra). If you don't know the answer to this then it's fine and you don't have to worry about it.
