Are these good parts for a dual water loop?
1. If that is the color setup you have picked then stay with red. But be prepared to change fluids and/or pick the CPU and GPU block
apart for cleaning around 4 - 6 months down the road. If you are unlucky you need to do this sooner, opposite when you ofc are lucky 😀
Just make sure you REALLY clean the radiator before you install it into the loop!
2. Ok fans.
1. What color should I use then, my setup color scheme is black, red, and grey.
2. I'm planning on getting the Corsair ML120 Pro
2. Ok fans.
