Are these idle temps good or not
Mohit Valecha
36
cpu-8320 stock cooler 22C
mb- asus m5a97 17C
rear exhaust in push pull config
cpu heatsink stock cooler also attatched with xtra a 92mm fan for push pull config
The H60 is a great idea and will definitely lower CPU temps. May I suggest a different case? That one appears to be a bit cheap, and there are many others that I think look more visually appealing!
- Caleb
ya pls a case which I could get for a proper airflow i chose this just bcz it has a front fan plus two slots for upper layer of case fans 1 rear exhaust and bottom mounted psu
anything else I need is performance in gaming at load
wats ur opinion in case?>
