Question Are these normal clock/fan speeds/temps for idle? - NZXT Cam
Apr 25, 2019
Hello!
I was curious as to if this clock speed and the fan speed of my CPU (i7 6700K @ 4.00ghz) is normal for being at idle. Seems very high. If so, what can I do to fix this issue?
As for GPU (MSI GTX 1080 Gaming X Twin Frozr VI), temps seem a little bit high as well for idle along with the high running clock speed.
Any help/advice is much appreciated. In terms of what I've tried to do (thinking this isn't normal), I've made sure power settings are set to balanced, I've made sure my BIOS settings were all reset back to default, made sure my BIOS overclock settings were set to default, nothing is modified in MSI afterburner, found no programs running high in usage through my task manager, found no weird/unidentifiable programs in my program list, and have found no threats of virus or malware through Kaspersky Antivirus except for a pathway through my previous older running version of WinRar. I appreciate your help guys!
NZXT Cam Software Screenshot
t.leblanc
I am also having this issue thing is if I say try and render in marmoset or texture in substance painter I instantly over heat and the pc shuts down
