Are these part compatible? Will they fit in the case? And how will this build perform?
tomasandri
58
CPU - AMD A8-6600K 3.9GHz Quad-Core Processor
Cooler - Arctic Freezer 7 Pro Rev.2
Mobo - Gigabyte G1.Sniper A88X
Memory - Some sort of Mushkin 2x4 DDR3
Storage - Seagate ST2000DM 2TB SATA
Toshiba MKNSSDCR 120GB
Video Card - Gigabyte R9 270X
Power Supply - Inter-Tech Coba Nitrox 800W PSU, 80 Plus Silver, Modular
Optical Drive - Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer
Operating System - Windows 7 Home Premium SP1 (OEM) (64-bit)
How will this build perform in newer games like AC4, BF4, Crysis 3, Skyrim and such?
And I'm also wondering if this fits in my Thermaltake V3 BlackX case?
And oh yeah, please dont tell me that these parts are poor, I'll upgrade them in the future.
Get rid of that CPU and motherboard. Go with an i3 4130 or 4150, or an i5 4xxx series chip with an H97 board. Never heard of that PSU brand, and it is overkill anyway. A 600w seasonic, XFX, or Evga is sufficient. Coolermaster TX3 is better, and often cheaper. Avoid gigabyte graphics cards. Sapphire, XFX, MSI, or Asus would be better quality. It should fit in your case.
Why do you ask for opinions on a poor build then ask for it to not be called poor? You are using an AMD a series which has an integrated gpu. Driving the price up. In a system with a discrete graphics card an I gpu is not necessary. You could get s better cpu for ther money, because truthfully that cpu it's just meh.
I can't really give you a budget since I don't live in the USA. I live in Iceland and the prices are pretty fucked up and i don't have alot of choices. Just tell me what you'd suggest I change and I'll see what I can do.
Okay. A bit of info.
First, the mobo: I only have access to Gigabyte motherboards. And really not that many. I found a Gigabyte S1150 GA-H97N-WIFI mobo but it's a tad expensive.
Second, the CPU: I dont have access to i3 4130 or 4150. I can get an i5 4xxx but then I'm over my budget.
Third, the PSU: I only have access to PSU's from Inter-Tech, Thermaltake, Fractal Design, Coolmax, Powerlogic and Armageddon.
Fourth, the cooling: I have access to a bunch of coolers. No more on that.
Fifth, the graphics card: I only have access to Gigabyte ones.
As you can see, living in Iceland limits my choices ALOT.
