Are these parts compatible? (First build)
Northfleet
7
Hey guys,
I'm planning to build my own computer for the first time but I'd just like to check whether the parts are compatible so I don't waste a bunch of money.
The parts:
http://www.scan.co.uk/products/27-acer-s271hlabid-led-monitor-full-hd-hdmi-dvi-vga-1920x1080-250cd-m2-100m1-2ms
http://www.ebuyer.com/252858-seagate-1tb-barracuda-internal-hard-drive-st31000524as
http://www.ebuyer.com/259863-microsoft-windows-7-home-premium-w-sp1-licence-and-media-1-gfc-02050
http://www.ebuyer.com/410560-liteon-ihas124-24x-dvd-rw-dual-r-ram-sata-drive-internal-black-ihas124-19cu
http://www.ebuyer.com/339598-corsair-8gb-ddr3-1600mhz-vengeance-memory-cmz8gx3m1a1600c10
http://www.ebuyer.com/389855-coolermaster-silencio-650-with-gx-lite-700w-silencio650-lite700w
http://www.scan.co.uk/products/asus-b85m-g-intel-b85-s-1150-ddr3-sata-iii-pcie-30-(x16)-d-sub-dvi-d-hdmi-matx
http://www.ebuyer.com/391821-xfx-hd-7970-black-dd-edition-3gb-ddr5-dvi-hdmi-dual-mini-fx-797a-tdfc
http://www.ebuyer.com/467647-cpu-core-i5-4670k-3-40ghz-lga1150-box-bx80646i54670k
http://www.ebuyer.com/495088-edimax-300mbps-wireless-pci-e-adapter-v2-ew-7612pin-v2
http://www.amazon.co.uk/Expert-Gaming-Multimedia-Keyboard-Killing/dp/B00EJFSWXY/ref=sr_1_11?s=computers&ie=UTF8&qid=1382462219&sr=1-11&keywords=Aula
http://www.ebuyer.com/567933-ssd-530-series-120gb-2-5-7mm-1p-oem-ssdsc2bw120a401
I'd appreciate a speedy response as I would like to order the parts before Christmas.
PS: I didn't know where to put this so feel free to move it.
I notice that you are using a B75 chipset motherboard (non-overclocking) and a 4670k cpu (overclocking). You might want to change either your mobo if you plan to overclock (look for a Z87 series mobo) or your cpu if you are not planning to overclock (llok for a non-"k" series cpu) Also, if you plan to overclock, you will want to get an aftermarket cpu cooler such as the Cooler Master Hyper 212 Evo (or Plus), both reasonably priced and good for light to moderate oc'ing.
Thanks for the speedy reply, I think I will replace the motherboard but will get the aftermarket cooler later as i don't intend to overclock straight away.
I hate to be a pain, but is everything else compatible?
Edit: Also would that cooler be any good for an overclock to something like 4ghz?
You can use B-75 or B-85 mobo. And buy Xeon 1230V2 or LGA 1150 Xeon 1230V3 and you do not need overclocking.
Xeon is fast enough with stock clocks.
Do it like this. Just buy SSD + maybe cpu cooler for more silent build.
CPU: Intel Xeon E3-1230 V3 3.3GHz Quad-Core Processor (£185.99 @ Aria PC)
Motherboard: Gigabyte GA-B85-HD3 ATX LGA1150 Motherboard (£65.80 @ Amazon UK)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory (£62.99 @ Novatech)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive (£42.50 @ Aria PC)
Video Card: Zotac GeForce GTX 770 4GB Video Card (£287.72 @ Scan.co.uk)
Case: Fractal Design Define R4 (Black Pearl) ATX Mid Tower Case (£75.65 @ Ebuyer)
Power Supply: Corsair Professional 650W 80+ Gold Certified Semi-Modular ATX Power Supply (£48.59 @ Overclockers.co.uk)
Optical Drive: Samsung SH-224DB/BEBE DVD/CD Writer (£12.50 @ Ebuyer)
Total: £781.74
(Generated by PCPartPicker 2013-12-08 13:40 GMT+0000)
or if you want to OC. Then like this.
CPU: Intel Core i5-4670K 3.4GHz Quad-Core Processor (£165.90 @ Amazon UK)
Motherboard: Gigabyte GA-Z87-HD3 ATX LGA1150 Motherboard (£84.66 @ Amazon UK)
Total: £780.51
(Generated by PCPartPicker 2013-12-08 13:43 GMT+0000)
This is good cpu cooler.
http://www.aria.co.uk/Products/Components/Coolers+-+Air/CPU+Coolers/Thermalright+HR-02+Macho+Rev.A+%28BW%29+Performance+CPU+Cooler+?productId=53398
And SSD is good buy for new build.
http://uk.pcpartpicker.com/part/sandisk-internal-hard-drive-sdssdhp128gg25
Bigger is better.
http://uk.pcpartpicker.com/part/sandisk-internal-hard-drive-sdssdhp256gg25
Intel xeon is like i7 for a price i5.
http://www.cpubenchmark.net/cpu.php?cpu=Intel+Xeon+E3-1230+v3+%40+3.30GHz&id=1942
It do have 8 treads + HT
No iGPU so needs video card. But for gaming build video card is must have anyway.
But I do not know anyone who would not want i7 over i5 :)
Thank you very much for your help, From experience on other forums I thought it would take days to get a reply so thanks again.
