Are these parts compatible
Evil Bertie
Hey does anyone know if these parts are compatible
Seagate 3tb 3.5inch 7200rpm 64mb cache sata3 hard drive £93.74
Cooler master hyper 212 evo (120mm) £26.26
Amd fx6300 black edition 6 core (3.5/4.1ghz, 8mb level 3 cache, 6mb level 2 cache, socket am+,95w, retail boxed) £85.39
Sapphire 11200-07-20g graphics card (2gb,hd7850,gddr5) £140,00
Benqg12450E 24 inch widescreen full hd led monitor (1920+1080,5ms,VGA,dvi-d, brilliant image quality, 1080p 16:9 visual perfection
Zalman z9 plus midi tower case-black (atx,m-atx, 7 expansion slots, supports bottom psu installation, upto 7 system fans , tool free hdd installation) £59.28
Kingston tchnology hyper c ddr3 1600mhz c19 8gb SIMM memory module £61.99
Coz ocz-zs650w zs series 650w
80 plus bronze certified power supply
Asrock fm2a75 pro4 motherboard (socket DMV, amd a25 Fch, ddr3 data 600, atx ,pc:express 2.0, 7.1 channel hd audio) £55.69
Razor88
210
No. The motherboard is not compatible with your CPU.
Look at these:
http://pcpartpicker.com/parts/motherboard/
Those will be compatible.
I could suggest a better build for you if you want?
