Are these parts compatible?
yes they are compatible
suggestions
1. if you are not going to OC - get the i5 4690 / the cheaper i5 4460 there will be no performance it
2. go for a h97 mobo instead of a z97x which is meant for overclocking
3.your stock cooler is fine for no OCing
4. if you reduce on these costs you can manage an 980 / 770 sli with a psu upgrade
remember OCin reduces the life of your system and can potentially fry it if done incorrectly .
and you need to be really good and LUCKY(silicon lottery) if you intend to hit high OCs even with which you cannot see more than 5-10 FPS gains
hope this helps!
sir thx for your suggestions
i don't need to OC atm maybe after three years or even 4 years
but when that time comes i will be getting one more gtx
and oc the cpu
which i should buy liquid cooler for the cpu
in the mean while i just want to enjoy the performance so after i stated these points
should i change anything?
btw i just found that h97 is not compatible with sli nor crossfire
sorry, btw the 4th pt was in a different context than with the mobo pt, forgot to mention it(sorry!) and anyway try this as a cheaper alternative (z97 not z97x)
http://pcpartpicker.com/part/asrock-motherboard-z97extreme4
can you help me finding the proper gaming monitor for my gtx card is one has all i need for perfect performance?
http://www.amazon.com/VE248H-24-Inch-Full-HD-Integrated-Speakers/dp/B0043T7FHK/ref=sr_1_5?s=pc&ie=UTF8&qid=1416636190&sr=1-5
if you have any similar gaming monitors may you show me please?
my requirements are:
the refresh rate should be around 60Hz or 120Hz but 60Hz should be enough for this generation
resolution: 24-Inch LED FULL HD 1920x1080 cuz i want to have the best performance
the cost must be around 140-170$
ASUS or BenQ
for BenQ i found these
http://www.amazon.com/BenQ-GL2460HM-24-Inch-LED-Lit-Monitor/dp/B00IKDFL4O/ref=sr_1_4?s=pc&ie=UTF8&qid=1416684386&sr=1-4
http://www.amazon.com/BenQ-Gaming-Monitor-RL2455HM-24-Inch/dp/B007HSKSMI/ref=sr_1_7?s=pc&ie=UTF8&qid=1416684386&sr=1-7
for ASUS
http://www.amazon.com/Asus-VS248H-P-24-Inch-Full-HD-LED-lit/dp/B0058UUR6E/ref=sr_1_1?s=pc&ie=UTF8&qid=1416684765&sr=1-1
http://www.amazon.com/VE248H-24-Inch-Full-HD-Integrated-Speakers/dp/B0043T7FHK/ref=sr_1_2?s=pc&ie=UTF8&qid=1416684765&sr=1-2
help me choosing please and consider the price and performance
my rig is good enough to run most of games on ultra
i just think the less resolution the more fps you get and i think 1080 resolution is enough for perfect experience
i would suggest the asus VS model(withou inbuilt speakers) it is an IPS with less response time, so genraly less ghosting with sharper image quality
hope this helps!!
you mean this monitor?
yes, i have a 22inch one and it is decent enough
thx man
can you check my parts again i made some changes
http://pcpartpicker.com/user/zeed/saved/xcNBD3
are those compatible?
this is my final build no more no less
so take your time checking it please
no hard drive?
as far as i know he parts are compatible. the cooler is a bit large and there is a USB port location problem as said in the pc part picker page
having said that i am sure that it will work but if you want to be really really sure you can just create another thread.
hope i have helped you!
Really thx dude you helped me more enough
