Are these parts compatible?
Vulcan4499
15
Core Processor
Intel Core i3-6100 3.7GHz Dual-Core-$100
Motherboard
ASUS ROG STRIX B250F GAMING LGA1151 DDR4 DP HDMI DVI M.2 ATX Motherboard -$140
SSD
Kingston SSDNow V300 Series 120g 2.5"-$50
Ram/Memory
Corsair Vengeance LPX GB (1 x 8GB) DDR4-2400 Memory-$50
Video Card
EVGA GeForce GT 730 LP Low Profile Graphics Card - 2 GB GDDR5 - 64-bit - 902 MHz-$80
Gaming Tower
Raidmax Ninja II-$75
Power Suppy
500W Free With Tower
Total $500
If anyone could direct me to a store or website selling a good computer screen for around $100 that will work good with my setup that would be great thank you!
That's possibly the worst build i have ever seen, very badly unbalanced and make no sense. Is this PC supposed to be for gaming?
CPU: Intel Core i3-7100 3.9GHz Dual-Core Processor ($119.88 @ OutletPC)
Motherboard: Asus H110M-K Micro ATX LGA1151 Motherboard ($54.99 @ SuperBiiz)
Memory: Corsair Vengeance LPX 8GB (1 x 8GB) DDR4-2400 Memory ($47.60 @ Newegg)
Storage: Crucial BX200 240GB 2.5" Solid State Drive ($73.30 @ Amazon)
Video Card: PowerColor Radeon RX 460 2GB Red Dragon Video Card ($83.98 @ Newegg)
Case: Cooler Master N200 MicroATX Mini Tower Case ($31.98 @ Newegg)
Power Supply: Corsair CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply ($57.92 @ Amazon)
Monitor: Acer KN242HYL 23.8" 1920x1080 60Hz Monitor ($99.99 @ Newegg)
Total: $569.64
Generated by PCPartPicker 2017-02-19 13:50 EST-0500
Here is a much better PC that i would recommend to you, you may also want to buy a 1 TB HDD if you dont already have an SSD.
Thanks for sugar coating it as you realized I have no idea what I am doing.
I do have a 1 tb drive and a 1.5 tb drive
Would the build you recommended work with the tower I have above? I liked that one and it is cheaper considering it comes with a power supply...Yes it is meant for gaming.
Was the motherboard of any consequence as I would like to use that one, with the build you suggested...it does with with micro, mini, and atx....I have no idea :/
If you like the aesthetics of the case a lot go for it, however i would advise against it as it is quite poor quality.
Case: Raidmax Ninja II ATX Mid Tower Case ($48.99 @ SuperBiiz)
Total: $48.99
Generated by PCPartPicker 2017-02-20 13:18 EST-0500
Also, i doubt the powersupply that comes with this case is meant for gaming, if you could link me what power supply it is i can be sure. The motherboard that you like is a very good and nice mobo, but for that price its just not worth it. It would be a lot better to go for the $55 mobo above that i recommended and get put that extra $90 for a i5 7500, which will be solid improvement to your build, also the motherboard that you want offers features that you just wont be using, while the Asus H110M-K i suggested is a good quality mobo that get the job done.
CPU: Intel Core i5-7500 3.4GHz Quad-Core Processor ($196.33 @ OutletPC)
Total: $196.33
Generated by PCPartPicker 2017-02-20 13:25 EST-0500
Also another thing, if you don't care much about viewing angles much, i would recommend getting this monitor over the one i previously suggested, its 75Hz, meaning that the screen can display upto 75fps, and FreeSync, which eliminates the effect of V-Sync to remove screen tearing and produce stutter free gameplay. Also its 1ms response time, this doesn't matter much but its nice to have.
I recently took apart one of our old computers and retrieved an i7 920 cpu, is it worth using that or just sell it and get the i5 7500...As I mentioned earlier I have the 1 tb hdd and 1.5tb hdd, is it worth selling those both and getting a 250gb ssd? I'm not sure how much space I will actually need for having 5 or so games on my computer
I already added a 240gb ssd to the build list, if you were to sell your 1tb and 1.5 tb hdd's you may not have enough for another 250gb ssd. I would say keep atleast one of the 2 HDD's , as storage is very important and your SSD will fill way to fast with even 5 games. The i7 920 is roughly equivelent to a 4th gen i3, so your i5 7500 will be alot more powerful. Also another thing, instead of putting the extra $90 in to an i5 7500 over the i3 7100, it would be better to put it toward a RX 480 over an RX 470 (if your PC is primarily for gaming).
Video Card: Sapphire Radeon RX 480 8GB NITRO+ Video Card ($214.99 @ Newegg)
Total: $214.99
Generated by PCPartPicker 2017-02-20 19:35 EST-0500
What monitor is this? Thanks for the list I will most likely getting something along these lines.
