Are these parts compatible
adammihaljevich
Commendable
Oct 27, 2017
5
I'm going to build a computer and I wont to know if a Asus - GeForce GTX 1060 6GB 6GB Dual Video Card is compatible with Asus - M5A78L-M PLUS/USB3 Micro ATX AM3+ Motherboard thanks
Yes they are compatible. Make sure your PSU has the needed power connectors and is of sufficient strength to drive power that video card. Otherwise, punt to a 1050ti.
And like the previous poster implied, you can build your PC via parts picker and select that it enforce/check compatibility.
