Are These Parts Compatible
Oct 7, 2018
5
Hello, I'm gonna get straight to the point, i would like to know if these parts are compatible - https://au.pcpartpicker.com/list/XX6fD2
*NOTE* I already have the GPU, HDD, PSU, case and Mobo and i see that i have to install new drivers for the CPU/Mobo for it to work AND I'm currently searching for a wireless wifi adapter.
But my main concerns are the fan cables and all the wires and I'm not 100% sure if I am able to run these 4 fans, but tell me if any of you are able to find other problems.
I plan on having my build complete by the end of this year given that i would have the last extra bit of money from my birthday in November + Christmas. So it would be great to have this answered soon thanks
CPU: AMD - Ryzen 5 2600 3.4GHz 6-Core Processor ($234.00 @ Shopping Express)
CPU Cooler: EVGA - CLC 240 74.8 CFM Liquid CPU Cooler ($128.99 @ Mwave Australia)
Motherboard: Asus - PRIME B450-PLUS ATX AM4 Motherboard ($166.00 @ Shopping Express)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory ($218.00 @ Shopping Express)
Storage: Samsung - 860 Evo 500GB 2.5" Solid State Drive ($119.00 @ PCCaseGear)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($54.50 @ Shopping Express)
Video Card: Asus - GeForce GTX 1080 8GB ROG STRIX Video Card ($849.00 @ BudgetPC)
Case: Cooler Master - MasterBox Lite 5 RGB ATX Mid Tower Case ($89.00 @ IJK)
Power Supply: Corsair - CXM 650W 80+ Bronze Certified Semi-Modular ATX Power Supply ($109.00 @ Shopping Express)
Operating System: Microsoft - Windows 10 Home OEM 64-bit
Case Fan: Corsair - ML120 PRO RGB 47.3 CFM 120mm Fan ($36.50 @ Shopping Express)
Case Fan: Corsair - ML120 PRO RGB (3 pack w/Lighting Node PRO) 47.3 CFM 120mm Fans ($119.00 @ Shopping Express)
Total: $2122.99
Generated by PCPartPicker 2018-10-07 19:28 AEDT+1100
Your parts are all compatible.
I made some recommendations.
1. 2600 is cheaper and only 200mhz slower than 2600x. You can make up the difference with overclocking.
2. EVGA is cheaper, has RGB also, better performance and better software.
3. B350 motherboard may need a bios update. Get a newer b450 board.
4. Get faster RAM, it's also cheaper than what you had.
You dont need the fans , the case comes with 3 x rgb fans installed , & a plain black rear exhsust.
That case will not take a top mounted rad exhaust so not sure what your plans are regarding cooling layout. I would,drop the liquid cooling personally.
That motherboard requires a bios update to run a ryzen 2*** cpu, its not something you can do without an older gen 1 chip.
You should have gone b450 board wise.
Well I'm choosing to get the fans purely for a better look, and I'm not so sure what you meant by the whole radiator situation but from what i plan is to mount it on the front. in which it would be supported. And thanks, i was thinking about getting a new Mobo, i just wasnt so sure if it was worth selling and getting a new one but i think thats gonna be my next choice.
Do you have anything in mind for a different motherboard under 200$AUD. I was previously checking out that Asus PRIME B450-PLUS that you had listed. But i was just wondering as I'm not so familiar with the difference between motherboards. Motherboards are my weak point when it came to choosing a part
Motherboard: ASRock - B450 Pro4 ATX AM4 Motherboard ($149.00 @ Shopping Express)
Total: $149.00
Generated by PCPartPicker 2018-10-07 22:11 AEDT+1100
Motherboard: Asus - TUF B450-PLUS GAMING ATX AM4 Motherboard ($169.00 @ Shopping Express)
Total: $169.00
Generated by PCPartPicker 2018-10-07 22:13 AEDT+1100
These are the only other 2 I would recommend.
How about this, would it make a difference? https://www.scorptec.com.au/product/Motherboards/AMD-Socket-AM4/73785-GA-B450-AORUS-ELITE
Alright i guess thats all i would need then thank you so much.
