[SOLVED] Are these parts compatible?
Feb 13, 2019
11
So my friend asked me to choose the components for his brand new pc with $1400 as a budget. Can anybody check if the components are compatible? My friend wanted an RTX 2060 so I went with an 8th gen CPU. Will it still be ok?
The parts are,
I5 8400
MSI H310M Gaming plus
Thermaltake Versa h18
Team T Force dark 3200 MHz 16gb
Thermaltake 650w
WD Green 256gb
Segate 1tb
ASUS rtx 2060
cdrkf
1,909
17
12,665
248
So my friend asked me to choose the components for his brand new pc with $1400 as a budget. Can anybody check if the components are compatible? My friend wanted an RTX 2060 so I went with an 8th gen CPU. Will it still be ok? Parts on PCCasegear (Australia)
The link just goes to the store page, no parts listed...
Edit: Also can you mention what type of things your friend wants to do with the machine? Any specific games, other tasks?
Currently the AMD Ryzen 2000 series cpu's are generally better value than Intel unless you are looking super high end so I'd suggest basing the machine around something like the R5 2600X for that budget, although it does depend on what your friend is after...
Karadjgne
Herald
CPU: AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor ($244.00 @ Shopping Express)
Motherboard: MSI - B450M GAMING PLUS Micro ATX AM4 Motherboard ($125.00 @ Umart)
Memory: G.Skill - Aegis 16 GB (2 x 8 GB) DDR4-3000 Memory ($141.90 @ Newegg Australia)
Storage: Crucial - MX500 500 GB 2.5" Solid State Drive ($99.00 @ Austin Computers)
Storage: Western Digital - Caviar Blue 1 TB 3.5" 7200RPM Internal Hard Drive ($54.50 @ Shopping Express)
Video Card: EVGA - GeForce RTX 2060 6 GB XC GAMING Video Card ($559.00 @ Skycomp Technology)
Case: Cougar - MX330 ATX Mid Tower Case ($55.00 @ BudgetPC)
Power Supply: SeaSonic - FOCUS Gold 650 W 80+ Gold Certified Semi-Modular ATX Power Supply ($129.00 @ Mwave Australia)
Total: $1407.40
Generated by PCPartPicker 2019-04-13 16:36 AEST+1000
Similar threads
