Are these parts compatible?
Technoflicks
55
CPU: Intel Core i5-3570K 220$
power supply: CORSAIR Enthusiast Series TX750 V2 750W ATX12V v2.31/ EPS12V v2.92 80 PLUS BRONZE 110$
video card: ASUS HD7870-DC2-2GD5-V2 Radeon HD 7870 GHz Edition 2GB 256-bit GDDR5 260$
cpu cooler: Hydro Series™ H100i Extreme Performance CPU Cooler 119$
case: COOLER MASTER HAF 922 RC-922M-KKN3-GP Black Steel + Plastic and Mesh Bezel ATX Mid Tower Computer Case with USB 3.0 and Black Interior 99$
RAM: G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 41$
motherboard: GA-Z77X-D3H (http://www.newegg.com/Product/Product.aspx?Item=N82E16813128546) 134 (119)$
disk space: Still deciding
I am either getting a 7200RPM drive or a 10000RPM drive.
Is this all correct?
PCPartPicker...
PCPartPicker part list: http://pcpartpicker.com/p/tXtc
Price breakdown by merchant: http://pcpartpicker.com/p/tXtc/by_merchant/
Benchmarks: http://pcpartpicker.com/p/tXtc/benchmarks/
CPU: Intel Core i5-3570 3.4GHz Quad-Core Processor ($209.99 @ SuperBiiz)
Motherboard: Gigabyte GA-Z77X-D3H ATX LGA1155 Motherboard ($126.47 @ NCIX US)
Memory: G.Skill Ripjaws Series 8GB (2 x 4GB) DDR3-1600 Memory ($40.93 @ NCIX US)
Video Card: Asus Radeon HD 7870 GHz Edition 2GB Video Card ($239.99 @ NCIX US)
Case: Cooler Master HAF 922 (Black) ATX Mid Tower Case ($89.99 @ Amazon)
Power Supply: Corsair Enthusiast 750W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply ($89.99 @ Newegg)
Total: $852.36
(Generated by PCPartPicker 2012-12-24 17:58 EST-0500)
If so, then your build is 100% compatible. As for Storage, I recommend http://us.ncix.com/products/?sku=58746&vpn=ST31000524AS&manufacture=Seagate&promoid=1285
Nice build, all in all.
Thank you, the reason why i couldn't figure this out myself is because my retarded computer can not show a website correctly.
Retarded computer specs:
CPU: Mobile Intel Pentium T2060 @1.6GHz its also built on 65nm technology http://ark.intel.com/products/28021/Intel-Pentium-Processor-T2060-1M-Cache-1_60-GHz-533-MHz-FSB
Video Card: Integrated (struggles with 480p on YouTube )
RAM: 4 gigs of ddr2 (32 bit only recognizes 3.1 gigs)
OS: The main reason for my problems Windows VISTA 32 BIT the most GLITCHY OS in the world, I would rather have Linux.
my CPU cooler also makes a racket at 50% load.
(i have had to restore my computer to factory condition 3 times for it to work properly, the first time it wouldnt load the internet, thought it was broken for 3 months, 2nd time it had a virus, 3rd time i had a usb flash drive to install a security system and had 2 trojans removed)
You might think im joking but im not.
Haha no problem! I have a retarded computer too, games run fine but after 5 minutes the Laptop gets hot and I get serious FPS Drop. And I have Vista 64 and I like it well enough, but on my computer I'm building I am going to use Linux until I can afford Windows 7.
wow, i get 12 FPS on minecraft on tiny
If you want more FPS get the optifine mod, it is VERY easy to install, just make sure you install the right version, it basically uses 2 CPU cores instead of 1 and it allows you to lower detail and animation settings even more. (the installtions process is the same in all the versions of it so you can use the same process it used in its version 1.1 as the newest 1.4.5) If it doesnt work, restart minecraft and hit Force Update.
I use optifine. I love it.
My parent has a Windows 8 laptop. It sucks. Get Windows 7. Trust me, it is cheaper, most parts are compatible with it and games almost always work on Windows 7, while some haven't updated to work on windows 8. And as for GPU's, I am really not the guy to talk to. I keep hearing stuff about the 7770, but I have no idea. GPU is probably going to be the last thing I buy, as I am going to save up and buy one of the best ones that I can use with my motherboard/Cpu without bottlenecking.
