Are these parts compatible?
applesfaceman
44
harddrive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136891
memory
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231321
motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128487
cpu
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115078
im trying to make a computer that will be really strong and work well for a long time. its for a business (college bridge program)
do these parts work together well? im pretty confident they do but id appreciate some input.
thank you
BlackHawk91
224
Sure, you could look after G.Skill Ripjaws X / Sniper memory kits, Corsair Vengeance is also well reviewed. http://www.newegg.com/Product/Product.aspx?Item=N82E16820231461 that's a low voltage kit for just $60. ( Make sure the Ram is optimized/compatible with your mobo)
If you let me, I would also suggest this Hard drive http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185&Tpk=spinpoint%20f3 it performs better and is more reliable than the WD, and also cheaper.
And this mobo is more futureproof http://www.newegg.com/Product/Product.aspx?Item=13-157-265&SortField=0&SummaryType=0&Pagesize=10&PurchaseMark=&SelectedRating=-1&VideoOnlyMark=False&VendorMark=&IsFeedbackTab=true&Page=2#scrollFullInfo. Great features, good price. It will support PCIe 3.0 with Ivy Brige CPU's.
Let me know any doubts you have.
applesfaceman
44
could you explain how the hard drive is a better preformer?
the one i was looking at was a 6gb /s and this one isnt.. is that not to important? i guess that depends but what is it responsible for exactly
BlackHawk91
224
Well, actually there isn't a hard drive capable of using 3Gb/s full bandwidth . Only SSD's benefit from SATA III 6Gb/s (most of them are ok with sata II). Look here: http://www.tomshardware.com/charts/2009-3.5-desktop-hard-drive-charts/h2benchw-3.12-Avg-Read-Throughput,1010.html. Here is a list of benchmarks for hard drives performance: http://www.tomshardware.com/charts/2009-3.5-desktop-hard-drive-charts/benchmarks,50.html.
applesfaceman
44
so when the sata hdd says its 6gb that doesn't even mean anything? weak lol
