Are these parts quality?
clueless404
133
Hi guys, I have built a computer about 2 weeks ago and it's been working great. The only problem I have is my worry if it were to suddenly stop working. It took 4 months to get the computer working, for two main problems: the RAM wasn't on the QVL list, and every I started the build (external build at the time) it turned off after 3 seconds. Since then, I have got new RAM and a whole new Z97 mobo, as compared to the Z87. One day, the problem with it starting just vanished, and it started up, but failed to post until I got the new RAM. I know electronics can fail, but are any of these parts likely to fail in the next four years? Thanks- I really appreciate the help!
CPU Intel Core i7-4770K 3.5GHz Quad-Core
Motherboard Asus Z97-A ATX LGA1150
Memory G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-1600
Storage Mushkin Chronos Deluxe 240GB 2.5" SSD
Storage Western Digital BLACK SERIES 3TB 3.5" 7200RPM
Video Card Gigabyte Radeon R9 270X 4GB
Case Cooler Master Elite 431 Plus (Black) ATX Mid Tower
Power Supply XFX 750W ATX12V / EPS12V
Optical Drive LG BH16NS40 Blu-Ray/DVD/CD Writer
Ok- thanks! The reviews for the SSD are pretty good, so I feel ok. But if I were to get another SSD someday (or if this one crashed) how would I transfer Windows? The only way is to use the recovery disk I'm guessing? And would that even install it on another drive? Also- am I ok with stock cooling? Not doing any OC or gaming, just a bit of video editing at stock speeds. Thank you so much for the help- I appreciate it.
if you aren't going to overclock then don't waste your money of a K series CPU and a Z board. Save it and put it towards a better SSD or other components.
For transfer, best way it always do a clean install. But there are cloning softwares out there to transfer the data.
So other than those programs, buying a new copy of windows is the only way?
