Are these PC parts Compatable?
HarrisonG
24
This is the PC I'm planning to build, are alll of the parts compatable together, also, is it any good for gaming with?
Motherboard: ASUS M5A97 R2.0 AM3+ AMD 970 + SB950 6x SATA 6Gb/s USB 3.0 - £41.00
CPU: AMD FX 6300 - £69.00
RAM: Kingston tech Value RAM 1600 mhz 4GB DDR3 - £19.52
HDD: Hitachi 500GB 3.5" SATA Internal HDD 7200rpm HDS721050CLA362 with Certificate - £19.95
PSU: FSP 600W 80 PLUS SILVER Rated ATX PC Gaming PSU Quiet 120mm Fan 88% Efficiency - £34.00
GPU: (UNDER PONDER) Nvidia gtx 770 - £120.00
Case: Fractal Design Core 1000 USB 2.0 Micro ATX Case OEM - £19.99
Case fan: Arctic F8 Pro 80mm Case Fan - £3.96
GRAND TOTAL: £327.42
Drop the FSP PSU. It's a horrendous unit. I would go for an equivalent XFX unit, about £20 more. They're more reliable, longer warranty and higher quality. Here's one you'll like -
XFX TS 550w - http://www.cclonline.com/product/62301/P1-550S-XXB9/Power-Supplies/XFX-Pro-550W-Power-Supply-Unit/PSU0246/
OK, thanks, does the rest look OK? Will that PSU be able to power the gtx 770?
