Are these pc parts completely compatible with eachother?
whattheHONK
43
Hello! I am thinking of building my own pc, but i am very new to all of this, so i was wondering if someone could tell me if there are any compatibilty issues with these parts.
-Cooler Master Hyper 212 Evo Cpu Cooler with 120mm Pwm Fan RR-212E-20PK-R2
-Corsair Vengeance Blue 8 GB, 2X4 GB, PC3-12800 1600mHz DDR3 240-Pin SDRAM Dual Channel Memory Kit (CMZ8GX3M2A1600C9B)
-EVGA GeForce GTX780 Super Clocked with EVGA ACX Cooler 3 GB GDDR5 384 Bit, DVI-I, DVI-D, HDMI, DP, SLI Ready 03G-P4-2784-KR
-ASUS ROG, INTEL Z87, ATX LGA SOCKET 1150
-Intel Core i5-4670K Quad-Core Desktop Processor 3.4 GHZ 6 MB Cache - BX80646I54670K
-Western Digital 1 TB 3.5-Inch 7200 RPM SATA III 64 MB Cache Desktop Hard Drive WD10EZEX (Blue)
-Corsair CX Series 750 Watt ATX/EPS Modular 80 Plus Bronze ATX12V/EPS12V 744 Power Supply (CX750M)
-Corsair Carbide Series 200R Compact ATX Case CC-9011023-WW
ANYTHING would be helpful.
Are all the parts going to fit in the case, and are they all compatible? is the Corsair PSU enough for the PC and is the CPU going to "bottleneck" the GPU? Also, if there is anything i should change to get the same performance at a lower price, i would like to know. Thank you!
whattheHONK
43
Thanks for the really fast answers. what kind of problems does the CX have though. i cant really afford the AX.
also, is this motherboard better? Gigabyte LGA 1150 Intel Z87 HDMI SATA 6Gbps USB 3.0 ATX DDR3 1600 Intel Motherboards GA-Z87-HD3
mazooni
554
58
Not sure what motherboard you had in mind at first because all you wrote was "ASUS ROG, INTEL Z87, ATX LGA SOCKET 1150" which just tells me the series, the socket, the chipset, and the form factor. Asus and gigabyte both make great motherboards, I personally prefer most asus boards depending on which you are comparing between gigabyte and asus. Your psu does not have to be corsair it can be from a different company.
whattheHONK
43
also there are different letters after some motherboards like Asus z87-A or Asus z87-C. does it have anything to do with what the motherboard has?
mazooni
554
58
This is a good psu.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817438025&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
