Are these sufficient specs for CAD design and assembly?
Squeeky
101
I'm part of a robotics team at my high school. We're looking to build 3-4 LAN-box type systems we can carry around for about $600 each. So far, I've configured three separate builds for this purpose. Would any of these be sufficient for modeling and assembling a functional 3D model of a complex robot (600+ parts) in Autodesk Inventor 2014? If not, what should I change?
Intel i5-4440: http://pcpartpicker.com/user/squeekybeef/saved/zMRqqs
AMD A10 5800K: http://pcpartpicker.com/user/squeekybeef/saved/Tz2zK8
Intel Pentium G3258 20th anniversary: http://pcpartpicker.com/user/squeekybeef/saved/DkFYcf
All builds can swap out the 500gb drive for a 128gb SSD. A wise decision, or a waste of 3 extra dollars?
I would probably drop to 8GB RAM and up to a 250GB SSD.
You are changing your requirements.... Your question was about a design box. BUT...
Are you planning on running a hypervisor and VMs or just multiple programs simultaneously?
With an SSD and swap file, I don't think you would too limited for multiple simultaneous programs. With a hypervisor you might be depending on how many VMs you wanted to try an run.
My apologies. By "multitasking" I really meant that I would be working with multiple files at once within Inventor. I have no intention of running VMs.
I look at that use case similar to multiple programs and task switching. Only one or two are really active. I would think that you would still be OK with 8GB. Again, with prices the way they are now, I wouldn't recommend a 128GB SSD only. For a single drive system I would go with the 250GB.
How's this?
http://pcpartpicker.com/user/squeekybeef/saved/VH6KHx
I'm thinking a single stick of 8GB over 2x4GB so that there's an extra slot for the future.
Okay, here's what I speculate will be the final build. Despite what Autodesk's website lists
(see: http://knowledge.autodesk.com/support/inventor-products/troubleshooting/caas/sfdcarticles/sfdcarticles/System-requirements-for-Autodesk-Inventor-2014-products.html),
I trust this will have the power to model 1000+ part assemblies in Inventor 2014. If there are any other recommendations, please let me know!
http://pcpartpicker.com/user/squeekybeef/saved/M8WKHx
Thank you for your help so far.
