Question Are these temps normal for RTX 4080 Rog Strix?
ShadowRD
114
9
18,695
this is after a 3 hour gaming session
I have 2 years running a custom water loop with an ekwb water block. i just wanna know if i need to check thermal pads, paste or something else. Or, that peak on max temp hot spot is normal.
In the years, how many times have you torn down the loop and inspected the restrictive parts of the loop? No those temps aren't what you should be seeing when under watercooling. To add, did you perform any undervolting on your GPU?
Lastly, please pass on the parts list for your watercooling loop in the image posted above.
I really haven't opened the water block of the graphics card yet, even after two years, and I honestly don't know if the temperature has been like that from the beginning because I only recently started checking it.
Main Parts:
- CPU block EK-Quantum Velocity² D-RGB
- GPU block EK-Quantum Vector² EVO Strix/TUF RTX 4080 ABP Set D-RGB
- Pump/Reservoir EK-Quantum Kinetic TBE 200 D5 PWM D-RGB
Hmm, your maximum percentage power utilization was only getting up to 77%. Not a great sign if you don't have any frame limits in place.
2 years is a good while, maintenance is certainly due.
Thanks for your response.
I'm waiting for some thermal pads I just ordered to open it up and clean everything
