generally speaking, a HDD (or SSD) is always going to be more reliable than a flash drive. USB flash drives are made to TRANSFER files, not to store them. Still, you get what you pay for, and I have had a few flash drives that have lasted a very long time.
The bigger issue than reliability is that of redundancy. If you do not have a file in at least 3 locations (one of which is off site) then you didn't really care about the file. All of my files live on my HDD, and are then backed up nightly to a RAID1 array. Bulk media like music and movies are also backed up on optical media (typically the original disc it came on, but home made stuff is burned to disc), while smaller media like pictures and documents get backed up on cloud services.
There is then a small army of flash drives and external HDDs that I have for various projects, but I treat these as file transfer devices as I do not trust them in any kind of long term fashion.
If you really only have 30GB of files to back up then I would throw $20 at a cloud storage solution as that is the cheapest and (typically) most reliable solution. Getting an external 1TB HDD will only cost you ~$75, but that is a lot of wasted space... though you would be amazed at how quickly it can fill up! The other option is to get an external SSD; they are a bit more expensive per GB, but they are a lot faster, and if you are in a mobile situation they can take a lot more of a hit than a HDD can.
But, while you should absolutely have a 32-64GB flash drive, you should never trust them for storage as they are easily broken or misplaced.
