Are using 2 molex to 8pin power cables safe for gpu
Afshan_1
Commendable
May 7, 2016
20
Graphic card needs one 8pin power but my psu only has a one 6pin pci cable.so should i buy a 2 molex to 8pin adapter? And is it safe?
It's the exact same as when you plug the PCI-E cable into the GPU.
Just do it the exact same way with the adapter and plug the adapter end into the GPU and you're good to go.
Also, the adapter has to be for the PCI-E cables, it has to have the exact same amount of pins and either be male or female.
Also, as long as your PSU is fine and the adapters work with it, continue using it.
But, try and upgrade it in the future as well to a Corsair or something.
Thanks.I have a Zebronics 700w psu which has 35A for +12v,asi am buying an asus r9 380 i am confused whether to use this psu..how to connect the adpaters...are all molexes 12v? can i connect the adapter to any of the two molexes?
It all depends on the PSU quality
Based on your PSU I'd say don't even try try 700w PSU should have a least 2. 8pin pcie connecters
And 35a on a 700w PSU is pretty poor it should be capeable of over 50a on the 12v if it was of any quality
My opinion is that PSU deserves to be in the trash
Not exactly all about the PSU not giving enough power. It's more about that it's extremely hard to find a 6+2/8 pin PSU to 6+2/8 pin to PCIE cable so we have to settle for molex.
