L LinkedPc Honorable Jul 1, 2013 51 0 10,630 Aug 3, 2016 #1 By "daily chain" cable I mean THIS. For example would that work on a something like a gtx 980 or would you have to connect two different 6/8pin cords. Thanks.
Solution S S Suztera Aug 4, 2016 Yes you can use that cable safely if it is provided alongside with your power supply.
S Suztera Polypheme Mar 18, 2014 12,729 0 60,960 Aug 4, 2016 Solution #2 Yes you can use that cable safely if it is provided alongside with your power supply. Upvote 0 Downvote Solution
