Question argb 140mm fans recommendation
froggy8
691
63
10,970
hi guys,
took me awhile to choose the argb controller but we got there (thanks to this forum) , problem is they all have their own proprietary connectors. i originally planned to get pahnteks halo but just thought to make things simple, i will just get the same brand fans as the controller which is cooler master.
which argb cooler master 140mm fans do you recommend please?
many thanks
Reactions: froggy8
Might I ask what you narrowed down to from Cooler Master? Is it this one or this one? You should invest into the ecosystem that the controller's brand is from to make life simpler. If so, you're open to practically any fans within Cooler Master's portfolio. Case fans or will they double as radiator or heatsink(CPU cooler) fans?
Here's a shortlist;
https://www.coolermaster.com/catalog/coolers/#!/Fan Size=140+120/Fan - LED Lighting=ARGB
hi
i went with this one:
so far all i want are case fans and strips.
if i could get the halo to keep budget down then halo will be ok too.
sorry bit confused at the part you said 'You should invest into the ecosystem that the controller's brand is from ' what do you mean please?
many thanks
