Afternoon all,
Recently i built my new first Pc by own (proud of it ) 😀
My mother board is a MSI Pro Z790-A with i5-13600k
Everything was great till i noticed that my Cpu Liquid Cooler (Be Quiet! Pure Loop 2 FX 360mm) is working except for the rgb lights
I tried to check if anything happens with Mystic Light but failure
So every fan had the power and argb 3-pin that connected to Hub
Hub conncted to motherboard and supply power through Sata cable to PSU (Be Quiet! Power 12M 1000W)
Easy to connect even for an amateur and believe i 'm not
I did everything
Pls any help would be really helpful....
https://streamable.com/p43iv6 ----> in video there is Green Flashing after I apply to Mystic Light
Thnx in advance
Stamatis
I did everything
- updated bios to new one
- plug fans alone on Arbg header on mobo (has 3 of them) etc
Thnx in advance
Stamatis
