Any idea on how to control fan speed with a 3-pin ARGB header? I just bought a ThermalTake case with two 200mm ARGB fans. Since the fans get their power and RGB codes over the same wires, there isn't any control of the fan speed.
I've been searching and searching and it seems like it's not something that is done. Speed control is listed for 4-pin connectors, but that means 12v. PWM isn't even mentioned for 3-pin, 5v connectors.
Mystic Light doesn't mention fan speed or RPM in the manual, and while MSI's Dragon software mentions fan speed, per their website it is only compatible with X570 motherboards. And I've looked at stand-along ARGB controllers from Corsair, Phantek, Silverstone, Cooler Master and ThermalTake. They all get power from SATA and none of them mention anything at all about fan speed. The only "speed" control is over the lighting effects...
