[SOLVED] ARGB controller not detected by Masterplus
edilovdeni208
Commendable
Jun 2, 2018
18
Hello,
I have a problem with my fans, mf120 halo fans 3pack with a controller. My pc is very loud even after like 10 mins of gaming, I have to restart it so it slows down. Also the rgb is weird, I first connected them trough my mb but gigabyte software is bad so I pulled it out, put it trough the controller but the mastercooler software cant seem to find the controller.
What do I do?
thank you in advance,
https://imagizer.imageshack.com/img923/9647/6tCFV8.jpg
https://imagizer.imageshack.com/img923/1184/hdFkND.jpg
https://imagizer.imageshack.com/img923/6428/eUSdwP.jpg
AA.
When do you get this message? downloading it or running it?
If it comes up when running it, they proabably are looking for you to plug the controller into a USB port.
I assume you did verify the model# of your controller is one supported by the firmware update.
