Question ARGB Fans and Mobo compatibility
Oct 30, 2020
Hi,
I just got a new case and want to spruce it up and have a few questions.
So I'm going to be installing 3x140mm and 1x120mm all ARGB.
My question is if I can bypass having a controller for the ARGB, since I have a B550-F Motherboard that comes with an ARGB header, can I simply use a 5 splitter and connect the 4 fans+led strip onto the header and control everything from the aura sync menu?
Thx in advance
Oct 30, 2020
81
Not sure how many you can run off a single header but they wouldn't be individual control. For fans could probably work out ok but for rgb they all be doing same thing so might be disappointment to you. Aura is ok but thats as much positive as I can say for it. My suggestion is consider maybe commander pro.
