[SOLVED] aRGB fans flickering then lights go out ?
Top fans and back fans - correct?
Loose connection or even a "make and break connection" (broken wire inside a cable that touches and stops touching along the conductor itself.)
Disconnect all affected fans. Connect the "first fan" and determine if the problem continues.
If not, then add a second fan, a third fan, etc. Wait long enough between fans to allow warming up and some "spin time".
Work through all six fans.
If not successful then do again but change the fan's order.
Run individual fans without the converter - determine if any fans fail.
Overall, you must methodically troubleshoot fans and connectivity to locate the source of the problem.
Basically working through what works and continues to work and which...
Basically working through what works and continues to work and which fan/connection causes problems.
Number the fans and diagram the connections in order to keep track of what you test and the results.
