Question Argb lights of fans problem in pc
mahar116
15
Processor Intel corie i5 13400f
Motherboard Asus Prime B760m-A wifi DDR5
Ram G.Skill Ripjaws S5 6000mhz
Nvme lexar Nm720 1tb
Vga Card Nvidia Rx4060 8gb
CPu Coolar Thermalright assassin king 120 se
PSU Corsair cx 650 80 plus brownz
Case Ease 125 b with eight argb infinity fans
My problem is related to argb lights of all case and cooler fans. All fans are link with motherboard argb header and argb lights effect of fan are set with Asus Armoury crate software. When i turn on my pc all lights of argb nine fans are running fine but after a 10 or 15 seconds all lights of argb fans turn off for a 3 to 5 sec (All fan and pc are running fine without argb lights) than the lights of fans are turn on again and then runs fine after that. Is it is normal behavior of argb lights of fan.
Thanks in advance.
Just sounds like some sort of software loading procedure and when the software's ready everything's fine. Most systems and argb devices start out with the default fabled rainbow pattern and when the software loads your personal setup pattern there's a momentary reset change and then its fine.
