Question ARGB lights on case?
Jun 27, 2019
Hi, I’ve got an Antec DP501 with built in lighting strips on the front of the case, apparently you’re supposed to plug one of two cables in to get them working but I can’t find where you’re supposed to connect them to? Motherboard’s a Gigabyte Z390 UD, apparently one of the cables is for Gigabyte motherboards only excluding my model so confused
Your MB does NOT have a 3 PIN ARGB (5V) header so you can NOT connect the ARGB LEDs to your MB.
Look at page 14:
http://download.gigabyte.asia/FileList/Manual/mb_manual_z390-ud_v2_e.pdf
You will need to buy an ARGB controller to use those 5V 3 pin ARGB LED strips.
Like this or a similar controller:
Or you can buy some 4 pin (12V) RGB LED strips and connect them to the MB header.
Like these:
https://www.newegg.com/phanteks-ph-ledkt-combo-multi-color/p/N82E16811984008?Item=N82E16811984008
