[SOLVED] ARGB Male to Male Pin??
I don't know where you can get those 3-pin gender-changer adapters. But you are right. If you just take some 4-pin adapters and use some wire cutters to snip off one of the pins (on both sides of the adapter), you can make them do the same job.
I don't know where you can get those 3-pin gender-changer adapters. But you are right. If you just take some 4-pin adapters and use some wire cutters to snip off one of thep ins (on both sides of the adapter), you can make them do the same job.
You again! haha. I ended up getting a new mobo
