Question argb problem
Goldhaven
Commendable
Aug 4, 2017
my argb fans blink sometimes. I read on here could be a power supply issue so to test that put a load on it (play a game) and if its a psu issue the fans will blink more . What is weird is when i run the load test the fans do not blink at all. Any ideas are welcome.
here is some of my specs if that helps
mobo - asrock 570 steel legend running asrock polychrome sync
cpu - amd ryzen 7 3700x
graphics - nvidia rtx 2060 super
ram - 16 GBDDR4-3200 Memory Module - ADATA XPG SPECTRIX D41 (RGB)
Lutfij
Make and model of your PSU? What fans are you working with and have you connected them to the necessary headers on the board(with a necessary hub/splitter)? Also, make sure you're on the latest BIOS update for your motherboard.
Goldhaven
Commendable
Aug 4, 2017
600 Watt - Thermaltake Smart Series - 80 PLUS Gold ..I will have to check the fans name brand and get back with you on that. Connections run from argb header to hub then from hub to 4 case fans. My bios is 1.90. I do not think its a faulty fan thou as i tested each one individually and they all blink even if just one is connected to hub. Thanks for reply.
