Question ARGB problems on EK-Nucleus AIO CR360 Lux D-RGB Pump ?
adrifoxbg
155
15
4,585
Hello, I've been noticing a strange problem for a few days.
The RGB circle on the pump usually rotates, but recently this has not happened, it just stands still.
Any change through Armoury only affects the fans, the pump does not respond.
When starting a game, the RGB backlight always changed to a single color, now it has no effect either.
I removed the CMOS battery for the whole night. This morning I turned everything on, did a factory reset and for 10-15 minutes everything was fine, then the pump backlight became static again even when I was not at the computer. I checked the cables, everything seems fine.
Does anyone have an idea what this could be due to, the pump itself or the RGB controller on the bottom after some risky BIOS update?
Thanks
I forgot to mention that the small logo below works in normal argb mode, but not the big circle.
