Question ARGB Splitter cable (2 to 1)
Sep 1, 2019
27
Hi,
I am struggling finding this type of cables.
I need two 2 to 1 ARGB splitter. At first i wanted to get the cooler master one, but it is pretty expensive and i would need to buy 2 of them as they are 3 to 1. The one branded Akasa is to short (12cm).
At the end, i found this on Amazon IT (i am from Italy):
https://www.amazon.it/dp/B07RGVSNY5/ref=cm_sw_r_cp_apa_i_07iRDbABYB9ER
is it ARGB? The connectors have 3 pin, but there is no mention of addressable RGB in the description.
Lutfij
You're supposed to stick to one ecosystem and make sure you're not jumping through hoops. In fact you should ideally purchase the CoolerMaster branded part. Your link also shows up as an RGB connector not ARGB.
Sep 1, 2019
27
Ok... unfortunately the cooler master splitter seems unavaible everywhere or shipped within 60/120 days 😣
