MOBO ASUS TUF X570
I'm still in the planning phase of building the PC but I got everything picked out but im trying to figure out if I could put my motherboard or fans at risk by putting to much into the splitters.
I plan to connect CPU ARGB, 5 fans ARGB that are connected to a hub, and GPU Support ARGB to a ARGB splitter 3 to 1.
Questions 1. Does it matter that a hub with 5 ARGB fans in a hub connected to a splitter with 2 other ARGB products will affect the motherboard or anything.
Questions 2. I'm confused about the 5 fans I linked below. I'm confused on how the hub and the 5 fans get the power if its from the motherboard or from the PSU. And how its controlled by the motherboard for fan speeds. Will it all work in the end?
- Im not to experienced in computer building so I've been doing a lot of research on this to make sure I buy parts that will all connect properly without any problems of over doing it with splitters
Links below in what im going to buy
ARGB CPU AIO
ARGB Splitter
5 ARGB Fans w/ Hub
GPU Support ARGB
End Build
ARGB CPU AIO
ARGB Splitter
5 ARGB Fans w/ Hub
GPU Support ARGB
End Build
