Arma 3 Low Fps
Fluffeh Panda
5
Hello I get terrible FPS in Arma 3. 30-40 in Singleplayer and 19 or less on most servers. My PC build is more than enough compatible for the game so I was wondering if you guys can help me out. Almost all other games work perfectly fine.
Specs:
Processor: AMD FX(tm)-9590 Eight-Core Processor
Speed: 4.7 GHz
Number of Cores: 8 (I unparked the all)
Video Card: AMD Radeon (TM) R9 390 Series
Dedicated Memory: 8192 MB
Pixel Shader Version: 5.1
Vertex Shader Version: 5.1
I tried making all the settings lowest to Ultra but nothing has worked.
I use these parameters:
Code:
-skipintro -enableHT -high -nologs -nosplash -maxMem=8193 -maxvram=4096 -cpuCount=8 -exThreads=7 -malloc=tbbmalloc
My CPU tempatures when playing is 27-35c
My guess is that you have the settings up too much. Lower most of the graphics settings then increase them one at a time until you are happy. You will probably notice that there are a few that are causing the game to bomb in FPS.
Have you tried adjusting the view distance, and some of the other shader settings in game? The view distance makes a BIG impact on the performance. Also try switching off the AA options.
Couple Questions,
What is your CPU % ingame ?
What is your GPU % ingame ?
What mod are you playing?
Have you tried starting the game with none of the start up parameters?
Do you have performance issues on other games?
