Finally started my build. One of the parts I couldn't get at Microcenter was the Lian Li Hydroshift 2. Bought from Newegg. Mounted the pump to the CPU and popped on the first 3 nuts to the mounting bracket. When I grabbed the 4th nut from the bag, it was defective. It looks like the end where the screw would insert was crimped in a vice or pliers.
I understand my options include disassembling and sending the entire cooler back for a replacement, but I'm hoping to avoid that. I reached out to Newegg and Lian Li. No response from Newegg, and it took a couple weeks for Lian Li to reply, at which point they said it would take at least 30 days for them to send me a replacement and suggested I find the part in a store or online.
I'm looking for suggestions. I haven't been able to find this particular nut online. I found 1 ebay listing that looked promising in the pictures (it was a mounting bracket and nuts from a Lian Li Galahad 2 cooler), but when it arrived the nuts were not compatible with mine. I drove an hour to Microcenter today and the service tech searched through their supplies, but didn't find any compatible nuts. None of the products they sell containing replacement screws/nuts have anything related to coolers.
Any ideas? I hate the thought of sending the whole thing back over a single nut and then possibly having some other issue with the new one in a month or so when I finally get it... Ugh.
Thank you for any help,
-Frank
-Frank
