G
Guest
Guest
COOL! 955df is COOL! It supports 1024x768@100Hz! Colors are awesomely crisp amd flatness makes awesome! BUT! The bottom line is curved! I couldn't find any adjusment for it on the panel! Upper line is straight but bottom just sux! I can adjust everything except bottom line(you know when you can choose to adjust geometry then Pincusion/trapezoid and you can adjust trapezoid by clicking up/down on the panel and picushion by clicking back/forward or something like that!you can make it stright on the left and right side, but you can't do it on the top or bootom! Arrow, do you have this problem too? With my last monitor I could adjust it...I don't want to send 955df back..I like it!but this thing makes it look horrible!)! There must be a way! Maybe a utlity that allows you to do that! I tried different resolutions, but still the same thing! I thought maybe it happens just in Windows ME but I installed 98SE and in all my games I see this curve! Or maybe because of the flatness! I can't adjust it!
