Artic cooler freezer 64pro motherboard compatability issues
frankenwookie
88
I have an ASUS A8N32-SLI deluxe and an Ultra Alluminus full black case. I fear that the copper cooling pipes on the asus and shear size of the fan may interfere with my rear 120mm fan. Is there anywher that I might find a compatibilty list?
I don't know about a compatibility list because your problem is quite specific. I am not quite sure of your problem though, is it a problem with a case fan or with the ac freezer 64 pro?
If the problem is with the AC freezer 64 pro then perhaps I can help you.
The first picture is of your motherboard
http://www.kholonar.plus.com/computer/a8n32sli.JPG
The second is my motherboard
http://www.kholonar.plus.com/computer/a8nsli.jpg
The third is my motherboard with the ac freezer 64 pro in.
http://www.kholonar.plus.com/computer/case_internals.jpg
As you can see, the ac freezer 64 pro doesn't go anywhere near the passive cooling on the motherboard. Oh, and the fan on the 64 pro is well above the RAM so unless you have some heavy duty RAM with those LEDs on top you have nothing to fear.
dont worry about it, it will work fine
I have to say that both of you guy's freakin' rule. Thanks for all the effort you put into helping me with my problem.
