Hi guys, I am trying to OC my 9900K.
I am able to reach 5ghz with 1.270V, problem is not stable for realbench getting high temps, after few minutes, occt and prime on small fft getting most of the times BSOD or high temps >95C too quick but I am able to do cinebench with 88 average degress 5150 points, and I tested 4 or 5 games with high demand without any issues at 60ºC max.
I think that maybe I need some fine tuning with some advices of people who really know much more about OC than me. Its the first time I am doing OC but at least I´ve been one hole week looking tutorials, testing, etc, but still a noob, must confess and every time I search for a new tutorial I feel even more lost and confused.
I´ve been following youtube guides, tutorials on webpages and forums, and I really can´t figure it out which one is the good one because practically every one has a different config. (some of them use XMP 1, others 2, some of them have svid activated, others disabled, some uses 45 core caché, others said to start on 43, others 47, and same with other options, so I am reaching a point where I dont know where am I, and what I should change or not.)
My pc specs
Asus Rog Strix z390 F gaming
AIO Corsair H100i (The Old One)
RAM Corsair Vengeance 3000mhz
Nvidia Geforce RTX 2070
Im going to post what I have actually on my bios and see if someone can help me fine tuning this, because I have the feeling its not only a voltage thing the problem I have....
My UEFI Options
AI OVerclock Tuner XMP I ( I go with XMP I because I read on some forums normally is more stable than II, but tried both)
BCLK Freq 100.000
ASus multi core enhacement Disabled, enforce all limits
SVID Behaviour Auto
AVX 0
CPU Core Ratio Sync all cores
Core Ratio 50
DRAM Odd Ratio Mode Enabled
DRAM Freq 3000Mhz
CPU SViD Support Disabled
CPU Core / Caché Current Limit Max. 255.75
Min CPU Caché Ratio 45
Max Cache Ratio 45
BCLK Adapt Voltage Disabled
CPU Core Voltage Manual
CPU Core Voltage 1.270
DRAM Voltage 1.350
CPU VCCIO 1.100
CPU System Agent Voltage 1.100
DIGI+POWER CONTROL
CPU Load Line Calib Level 6
Synch ACDC Loadline Disabled
CPU Current Capacity 140%
INTERNAL CPU MANAGEMENT
Intel SpeedStep Disabled
Turbo Mode Enabled
Long Duration 4095
Package Power 127
Short Duration Package power 4095
CPU POWER MANAGEMENT
Intel Speed Step Disabled
Intel Speed SHift Disabled
CPU C- States Disabled
GFG Lock Disabled
I mean, I can live with that and If I need to do some premiere etc, load the stock profile on bios and then changing for gaming again on uefi profiles, but If I can find something stable for everything it will be really great.
Hope somebody will find something I have wrong to get some improvement, I really dont want to push much more the voltage, considering I am reaching already some bad temps with this voltage (Which surprises me because I though my refrigeration was way more effective than it really is...)
Thanks in advance.
My pc specs
My UEFI Options
BCLK Freq 100.000
SVID Behaviour Auto
AVX 0
Core Ratio 50
DRAM Freq 3000Mhz
Max Cache Ratio 45
DRAM Voltage 1.350
CPU VCCIO 1.100
DIGI+POWER CONTROL
Turbo Mode Enabled
Long Duration 4095
Package Power 127
GFG Lock Disabled
Thanks in advance.
