Asking for help for this build
Mikerame
36
CPU :i5 6500
GPU: Gigabyte/Asus GTX 950 or GTX 1050 (can't choose, they cost the same, i wonder why)
PSU: Cooler Master b500 v2 500W
RAM: 2x4 gb HyperX 2133 DDR4 (will upgrade later for 16 gb)
STORAGE: Samsung 750 evo 120 gb ssd, WD Blue 1TB hdd
MOBO: now this is where i can't really decide, these are the plans:
-Gigabyte H110M-S2H
-Asus H110-Plus
-Gigabyte H170-HD3 or H170-D3H (only difference is the integrated lan and audio)
-Asus H170M-Plus
I'll buy an ATX case so mobo can be either ATX or mATX. I'm absolutely not familiar with b150 chipset. Also, as i see, h110 is enough, but do i miss out something important by not buying the h170?
A lot of people recommends me the MSI B150 Mortar, is that fine? And do u have any alternative for the PSU?
Get the GTX 1050 Ti if you can. If not then get the GTX 1050. MSI Has very poor quality control and bios issues so i would stay away from them although their motherboards look nice. An EVGA 500W at the lowest. If your bdget allows it then get a Seasonic M12II or S12II .
